주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
도움말
6단계 편집 중 —
단계 유형:
끌어서 재배열 합니다
Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
Gently remove the case to avoid damaging it. Do not try to force the case open.
The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
