주요 콘텐츠로 건너뛰기
도움말
26단계 편집 중 —
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 사용하는 안내서에 영향을 미칩니다.
단계 유형:
끌어서 재배열 합니다
Insert a Battery Blocker or other insulator underneath the logic board to separate it from the battery connector.
The battery blocker is an outdated way of isolating the battery, as you risk damaging the battery pins underneath the logic board. If you use this method, take extreme care to insert it gently and straight in the direction of the logic board. Don't significantly deform the the logic board as you do this. Don't twist or swing the pick side to side.
Leave it there to prevent the battery connector leads from making contact until you have completed your repairs.
The rest of the images in this guide show the logic board EMI shield reinstalled, which is incorrect. Follow the instructions, but keep the battery disconnected and do not reinstall the EMI shield until your repairs are complete.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
