주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
도움말
3단계 편집 중 —
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 포함하는 안내서 36개에 영향을 미칩니다.
단계 유형:
끌어서 재배열 합니다
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
Be sure you are prying up on the hinged retaining flap, not the socket itself.
Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
Use caution when freeing the cable, as it is strongly adhered to the logic board. If necessary, use an iOpener or hair dryer to heat the cable in order to soften the adhesive and make it easier to remove.
Lift the left fan out of the device.
When reinstalling the fan, it's easiest connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
