주요 콘텐츠로 건너뛰기
enTourage Pocket eDGe Battery Replacement
필요한 것
  1. enTourage Pocket eDGe Battery Replacement, Battery: 1 단계, 이미지 1/3 enTourage Pocket eDGe Battery Replacement, Battery: 1 단계, 이미지 2/3 enTourage Pocket eDGe Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe Battery Replacement: 2 단계, 이미지 1/1
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe Battery Replacement: 3 단계, 이미지 1/3 enTourage Pocket eDGe Battery Replacement: 3 단계, 이미지 2/3 enTourage Pocket eDGe Battery Replacement: 3 단계, 이미지 3/3
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe Battery Replacement: 4 단계, 이미지 1/1
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe Battery Replacement: 5 단계, 이미지 1/1
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Adrian Do
회원 가입일: 09/24/15
355 평판
안내서 3개 작성하였습니다
University of Alabama, Team 1-3, Sydow campbell Fall 2015 University of Alabama, Team 1-3, Sydow campbell Fall 2015 회원
UA-SYDOW CAMPBELL-F15S1G3
4 회원들
안내서 3개 작성하였습니다
댓글 한 개
Great tutorial! I have two of these. Does anyone know where I can buy a replacement battery? I have looked everywhere. I would retrofit if I could find one large and flat enough. 7.2v 2000mA. Hate to have to trash them but they don’t make parts anymore.
Ron - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 19
전체 시간: 1,449
