주요 콘텐츠로 건너뛰기
eufy RoboVac 11 Wheel and Wheel Motor Replacement
필요한 것
  1. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Front Cover and Motherboard: 1 단계, 이미지 2개 중 1개 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Front Cover and Motherboard: 1 단계, 이미지 2개 중 2개
    • Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
    • Keep track of these screws. They are the same length as the interior screws but wider in diameter.
  2. eufy RoboVac 11 Wheel and Wheel Motor Replacement: 2 단계, 이미지 2개 중 1개 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the six 7 mm screws on the bumper with the Phillips #1 screwdriver.
  3. eufy RoboVac 11 Wheel and Wheel Motor Replacement: 3 단계, 이미지 3개 중 1개 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 3 단계, 이미지 3개 중 2개 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the top plate from the body of the device.
    • Unplug the bumper from the motherboard.
  4. eufy RoboVac 11 Wheel and Wheel Motor Replacement: 4 단계, 이미지 2개 중 1개 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the three 10 mm motherboard screws with a Phillips #1 screwdriver.
    • Cleaning the motherboard and inside of the device outdoors with a compressed air cleaner will help the robot last longer.
  5. eufy RoboVac 11 Wheel and Wheel Motor Replacement: 5 단계, 이미지 2개 중 1개 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Unplug the cables from the motherboard.
  6. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Rolling Brush: 6 단계, 이미지 2개 중 1개 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Rolling Brush: 6 단계, 이미지 2개 중 2개
    • Remove the single 10 mm screw with the Phillips #1 screwdriver.
    • Remove the rolling brush.
  7. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: 7 단계, 이미지 3개 중 1개 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: 7 단계, 이미지 3개 중 2개 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: 7 단계, 이미지 3개 중 3개
    • Remove the wheels.
    • The removal of the two wheels is the same on both sides, but on the left side there is a motor in the way of the wheels.
    • Remove the single 10 mm screw with the Phillips #1 screwdriver and then pull upwards to remove the piece preventing removal.
  8. eufy RoboVac 11 Wheel and Wheel Motor Replacement: 8 단계, 이미지 3개 중 1개 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 8 단계, 이미지 3개 중 2개 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the three 10 mm screws with the Phillips #1 screwdriver.
    • Remove motors.
    • The process for removing the left and right motors is the same.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kyleigh Hill
회원 가입일: 09/27/22
277 평판
안내서 2개를 작성함
Utah Tech University, Team 1-3, McMurrin Fall 2022 Utah Tech University, Team 1-3, McMurrin Fall 2022 회원
UTAHTECH-MCMURRIN-F22S1G3
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 31
전체 시간: 2,060
