메인 콘텐츠로 스킵하기
도움말
Asus Vivobook Q301LA-BHI5T02 Back Cover Replacement
How to replace the back cover of the Asus Vivobook Q301LA-BHI5T02.
This guide will explain how to replace the back cover of this device.
단계 1 Back Cover  ¶
Make sure the computer is turned off.
단계 1 Back Cover  ¶
  • Make sure the computer is turned off.
  • Flip the device over so that the back cover is facing you.
단계 2  ¶
Remove the four 5mm Phillips #1 screws from the top of the laptop. Remove the two 6mm Phillips #1 screws from the sides of the laptop.
단계 2  ¶
  • Remove the four 5mm Phillips #1 screws from the top of the laptop.
  • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
  • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
단계 3  ¶
Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
단계 3  ¶
  • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
단계 4  ¶
Lift off the cover and remove the back cover from the device.
단계 4  ¶
  • Lift off the cover and remove the back cover from the device.
