메인 콘텐츠로 스킵하기
도움말
Samsung PL20 LCD Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
잘게 썰기
잘게 썰기
해당 안내서의 단계들은 분할되어 전제 조건 안내서들로 만들어져야 합니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
This camera had a few problems, but I started off by replacing the broken LCD. This is a nice camera to work on; it was a straight forward task to complete.
Here is a PL20 that has a broken LCD, as well as some other issues. The repair is straight forward. The only tools used were a Phillips screwdriver and a plastic opening tool, which is optional. This camera was actually fun to work on; it was easy and took no time at all.
단계 1 LCD  ¶
Here is the broken LCD.  The spider crack in the glass, as well as the discoloration of the screen, is clearly visible. Remove the battery and the memory card from the device, if so equipped. Remove the two screws on the left side.
단계 1 LCD  ¶
  • Here is the broken LCD. The spider crack in the glass, as well as the discoloration of the screen, is clearly visible.
  • Remove the battery and the memory card from the device, if so equipped.
  • Remove the two screws on the left side.
단계 2  ¶
Remove one screw from the bottom Remove the two screws on the right side. Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
단계 2  ¶
  • Remove one screw from the bottom
  • Remove the two screws on the right side.
  • Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
단계 3  ¶
Once the back of the case is removed, the LCD becomes immediately visible. Remove the LCD from its holder to gain access to the connector. Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
단계 3  ¶
  • Once the back of the case is removed, the LCD becomes immediately visible.
  • Remove the LCD from its holder to gain access to the connector.
  • Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
