메인 콘텐츠로 스킵하기
도움말
iPhone X Earpiece Speaker and Front Sensor Assembly Replacement
Remove/replace the earpiece speaker assembly in an iPhone X, including the flood illuminator, proximity sensor, ambient light sensor, and microphone.
  • 작성자: Adam O'Camb
  • 예상 시간 1 - 2 시간
  • 난이도: 보통
Follow the steps in this guide to remove or transfer the earpiece speaker and front sensor assembly in your iPhone X. This assembly includes the earpiece speaker, microphone, ambient light sensor, flood illuminator, and proximity sensor.
This assembly is paired to your individual iPhone from the factory, so you must transfer it from your old display to your new one during any display replacement.
The flood illuminator forms part of the biometric Face ID security feature, and Face ID functions will fail if the original component is damaged or incorrectly installed. Replacing it with a new part will also cause Face ID to fail, so take extra care not to damage any of these components during this procedure. If damaged, only Apple can restore Face ID function.
단계 1 Earpiece Speaker and Front Sensor Assembly  ¶
Remove the 1.2 mm Y000 screw on the back of the display assembly, near the infrared camera port.
  • Remove the 1.2 mm Y000 screw on the back of the display assembly, near the infrared camera port.
단계 2  ¶
Beneath the screw you just removed lies a small metal grounding clip. If it didn't already come out along with the screw, remove it now. During reassembly, orient the clip as shown. Hold the clip in position while you install and tighten the screw. During reassembly, orient the clip as shown. Hold the clip in position while you install and tighten the screw.
단계 2  ¶
  • Beneath the screw you just removed lies a small metal grounding clip. If it didn't already come out along with the screw, remove it now.
  • During reassembly, orient the clip as shown. Hold the clip in position while you install and tighten the screw.
단계 3  ¶
Remove two more Y000 screws securing the speaker/sensor assembly:
단계 3  ¶
  • Remove two more Y000 screws securing the speaker/sensor assembly:
  • One 1.6 mm screw
  • One 1.3 mm screw
단계 4  ¶
The earpiece speaker is lightly adhered in place. Using a spudger, gently pry under the top edge of the speaker assembly, and flip it over—down and away from the top edge of the display.
단계 4  ¶
  • The earpiece speaker is lightly adhered in place.
  • Using a spudger, gently pry under the top edge of the speaker assembly, and flip it over—down and away from the top edge of the display.
  • The speaker remains attached via a very thin flex cable. Be careful not to strain or damage the cable.
단계 5  ¶
Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for about a minute, in order to soften the adhesive securing the sensors.
단계 5  ¶
  • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for about a minute, in order to soften the adhesive securing the sensors.
단계 6  ¶
Carefully slide the flat edge of your spudger underneath the flex cable below the microphone. Twist gently to separate the microphone, while being careful not to strain or damage the flex cable. If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel.
단계 6  ¶
  • Carefully slide the flat edge of your spudger underneath the flex cable below the microphone.
  • Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
  • If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel.
단계 7  ¶
Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module. Gently wiggle and lift to separate the module from its notch in the front panel. It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
단계 7  ¶
  • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
  • Gently wiggle and lift to separate the module from its notch in the front panel.
  • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
단계 8  ¶
Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display. The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
단계 8  ¶
  • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
  • The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
단계 9  ¶
If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below. If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier. During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
단계 9  ¶
  • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
  • If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
  • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
단계 10  ¶
Remove the earpiece speaker and front sensor assembly. During reassembly, check the position of the black plastic module containing these components: Proximity sensor
단계 10  ¶
  • Remove the earpiece speaker and front sensor assembly.
  • During reassembly, check the position of the black plastic module containing these components:
  • Proximity sensor
  • Flood illuminator
  • The module must be positioned so that these components are not obstructed by any adhesive.
