도움말
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Sound Card Replacement
Replace your sound card to regain audio functionality.
단계 1 Sound Card  ¶
If necessary, remove the strip of tape covering the speaker cable.
단계 1 Sound Card  ¶
  • If necessary, remove the strip of tape covering the speaker cable.
단계 2  ¶
Pull the speaker cable connector straight up to disconnect it from the sound card.
단계 2  ¶
  • Pull the speaker cable connector straight up to disconnect it from the sound card.
단계 3  ¶
Remove the two T8 Torx screws securing the sound card to the lower case.
단계 3  ¶
  • Remove the two T8 Torx screws securing the sound card to the lower case.
단계 4  ¶
Use the flat end of a spudger to pry the USB sockets away from the left edge of the lower case.
단계 4  ¶
  • Use the flat end of a spudger to pry the USB sockets away from the left edge of the lower case.
단계 5  ¶
Lift the sound card slightly out of the lower case, minding the fragile lower portion holding the microphone connector.
단계 5  ¶
  • Lift the sound card slightly out of the lower case, minding the fragile lower portion holding the microphone connector.
  • The sound card is still attached to the PowerBook by the microphone cable.
단계 6  ¶
Pull the sound card ribbon cable straight away from its socket on the sound card.
단계 6  ¶
  • Pull the sound card ribbon cable straight away from its socket on the sound card.
단계 7  ¶
Use your fingernails to pull the microphone connector straight away from its socket on the sound card.
단계 7  ¶
  • Use your fingernails to pull the microphone connector straight away from its socket on the sound card.
