도움말
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Speakers Replacement
Is your PowerBook mute? Replace your speakers.
섹션
파일
단계 1 Speakers  ¶
Disconnect the RJ-11 cable from the modem.
단계 1 Speakers  ¶
  • Disconnect the RJ-11 cable from the modem.
단계 2  ¶
If necessary, remove the strip of tape covering the speaker cables.
단계 2  ¶
  • If necessary, remove the strip of tape covering the speaker cables.
단계 3  ¶
Use your fingernails or the tip of a spudger to separate the ZIF cable lock from its socket. The ZIF cable lock will move about 1 mm and stop. Do not attempt to completely remove the ZIF cable lock.
단계 3  ¶
  • Use your fingernails or the tip of a spudger to separate the ZIF cable lock from its socket.
  • The ZIF cable lock will move about 1 mm and stop. Do not attempt to completely remove the ZIF cable lock.
단계 4  ¶
Pull the DC-in ribbon cable straight away from its socket.
단계 4  ¶
  • Pull the DC-in ribbon cable straight away from its socket.
단계 5  ¶
Peel the DC-in cable off the adhesive securing it to the lower case.
단계 5  ¶
  • Peel the DC-in cable off the adhesive securing it to the lower case.
단계 6  ¶
If necessary, use the tip of a spudger to remove the small piece of foam tape from the side of the left speaker. De-route the AirPort antenna cables from the channel in the left speaker.
단계 6  ¶
  • If necessary, use the tip of a spudger to remove the small piece of foam tape from the side of the left speaker.
  • De-route the AirPort antenna cables from the channel in the left speaker.
단계 7  ¶
Remove the single 6.9 mm T8 Torx screw securing the left speaker to the lower case.
단계 7  ¶
  • Remove the single 6.9 mm T8 Torx screw securing the left speaker to the lower case.
단계 8  ¶
Lift the left speaker from its rear edge and maneuver it out of the lower case, minding the cables sitting in the channel near the front edge of the left speaker. Lift the left speaker from its rear edge and maneuver it out of the lower case, minding the cables sitting in the channel near the front edge of the left speaker.
단계 8  ¶
  • Lift the left speaker from its rear edge and maneuver it out of the lower case, minding the cables sitting in the channel near the front edge of the left speaker.
단계 9  ¶
Remove the single 6.9 mm T8 Torx screw securing the speaker cable ground loop to the lower case.
단계 9  ¶
  • Remove the single 6.9 mm T8 Torx screw securing the speaker cable ground loop to the lower case.
단계 10  ¶
Peel back the piece of foil tape covering the modem cable to free the speaker cable held underneath.
단계 10  ¶
  • Peel back the piece of foil tape covering the modem cable to free the speaker cable held underneath.
단계 11  ¶
Pull the speaker cable straight up to disconnect it from the sound card.
단계 11  ¶
  • Pull the speaker cable straight up to disconnect it from the sound card.
단계 12  ¶
In the next few steps, you will disconnect several ribbon cables that cover the right speaker cable.
단계 12  ¶
  • In the next few steps, you will disconnect several ribbon cables that cover the right speaker cable.
  • Use the flat end of a spudger to pry the hard drive ribbon cable connector up off the logic board.
단계 13  ¶
Use the flat end of a spudger to pry the sound card cable connector up off the logic board.
단계 13  ¶
  • Use the flat end of a spudger to pry the sound card cable connector up off the logic board.
단계 14  ¶
Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
단계 14  ¶
  • Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
단계 15  ¶
단계 15  ¶
단계 16  ¶
Pull the PRAM battery & USB board cable out of its socket.
단계 16  ¶
  • Pull the PRAM battery & USB board cable out of its socket.
단계 17  ¶
Use a spudger to de-route the display data cable from the channel in the right speaker.
단계 17  ¶
  • Use a spudger to de-route the display data cable from the channel in the right speaker.
단계 18  ¶
Use the tip of a spudger to pry the power button LED window off the right speaker.
단계 18  ¶
  • Use the tip of a spudger to pry the power button LED window off the right speaker.
  • Try to place the window curved-side down on your work surface to keep the adhesive around its perimeter clean.
단계 19  ¶
Remove the single T8 6.9 mm Torx screw securing the right speaker to the lower case.
단계 19  ¶
  • Remove the single T8 6.9 mm Torx screw securing the right speaker to the lower case.
단계 20  ¶
Lift the right speaker out of the lower case.
단계 20  ¶
  • Lift the right speaker out of the lower case.
단계 21  ¶
De-route the speaker cable from the clips along the front edge of the logic board.
단계 21  ¶
  • De-route the speaker cable from the clips along the front edge of the logic board.
  • The clips open in different directions, so be careful to not break any off during removal.
