메인 콘텐츠로 스킵하기
도움말
Disassembling Rival 16131 Toaster Shell
문법 검토
문법 검토
회원님 내면의 영어 교사를 인정하고 해당 안내서의 문법 향상에 도움을 주십시오!
더 많은 이미지가 필요함
더 많은 이미지가 필요함
몇몇 추가 이미지는 해당 안내서의 절차를 아주 명백하게 만들 것입니다.
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
This guide will show you how to open the toaster, including taking the cover and knobs off.
  • 작성자: Naomi Willis
  • 예상 시간 5 분
  • 난이도: 쉬움
단계 1 Shell Removal  ¶
Make sure the toaster is unplugged before starting. Turn the toaster upside down and remove the rubber feet.
  • Make sure the toaster is unplugged before starting.
  • Turn the toaster upside down and remove the rubber feet.
단계 2  ¶
Using a #2 Phillips head screwdriver, remove the four 12mm screws that attach the toaster shell. Using a #2 Phillips head screwdriver, remove the four 12mm screws that attach the toaster shell.
단계 2  ¶
  • Using a #2 Phillips head screwdriver, remove the four 12mm screws that attach the toaster shell.
단계 3  ¶
With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster. When reassembling the toaster, make sure that the back of the dial lines up with the slot both in position and orientation (the dial and slot are not perfect  circles - they have a notch). The only object holding the shell onto the  toaster now is the grey part of the lever.
단계 3  ¶
  • With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
  • When reassembling the toaster, make sure that the back of the dial lines up with the slot both in position and orientation (the dial and slot are not perfect circles - they have a notch).
  • The only object holding the shell onto the toaster now is the grey part of the lever.
단계 4  ¶
Reach under the shell and grab the back, white part of the lever.
단계 4  ¶
  • Reach under the shell and grab the back, white part of the lever.
  • Grab the grey lever between your index finger and your middle finger and pull.
  • Pulling too hard will break the mechanism that holds the grey handle onto the white lever.
  • Remove the shell.
