메인 콘텐츠로 스킵하기
도움말
2003-2007 Honda Accord Front Brake Pads Replacement
잠재적으로 위험한
잠재적으로 위험한
절차를 제대로 따르지 않을 경우 부상을 입을 수 있습니다. 주의를 요하며 모든 경고를 따라주십시오.
더 많은 이미지가 필요함
더 많은 이미지가 필요함
몇몇 추가 이미지는 해당 안내서의 절차를 아주 명백하게 만들 것입니다.
한 단계 누락
한 단계 누락
이런! 해당 안내서는 현재 몇몇 중요한 단계가 빠져 있습니다.
Instructions on how to replace the front brake pads on a 2003-2007 Honda Accord.
Brake pad life varies greatly by driving style and car use. There is no specific mile count at which brake pads should be changed. The best indicator of worn brake pads is a screeching sound when braking. It is recommended that you change your brake pads when this occurs.
단계 1 Front Brake Pads  ¶
Once car is raised, remove the lug nuts on one of the front tires with the 3/4'' socket.
  • Once car is raised, remove the lug nuts on one of the front tires with the 3/4'' socket.
단계 2  ¶
Remove the wheel and tire off the wheel studs, and place it aside. This exposes the caliper (shown in rectangle) and rotor (shown in circle). This exposes the caliper (shown in rectangle) and rotor (shown in circle).
단계 2  ¶
  • Remove the wheel and tire off the wheel studs, and place it aside.
  • This exposes the caliper (shown in rectangle) and rotor (shown in circle).
단계 3  ¶
Identify the two mounting bolts on the rear of the caliper. Using a 12 mm wrench or socket, remove the two caliper mounting bolts. Alternatively, you may remove only the bottom mounting bolt and, using the top bolt as a hinge, rotate the caliper up and away from the rotor to access the brake pads. If you do this, skip the next step.
단계 3  ¶
  • Identify the two mounting bolts on the rear of the caliper.
  • Using a 12 mm wrench or socket, remove the two caliper mounting bolts.
  • Alternatively, you may remove only the bottom mounting bolt and, using the top bolt as a hinge, rotate the caliper up and away from the rotor to access the brake pads. If you do this, skip the next step.
단계 4  ¶
Slide the caliper off and rest it on the top of the rotor. Do not let the caliper hang freely because the brake lines may stretch and weaken. Do not let the caliper hang freely because the brake lines may stretch and weaken.
단계 4  ¶
  • Slide the caliper off and rest it on the top of the rotor.
  • Do not let the caliper hang freely because the brake lines may stretch and weaken.
단계 5  ¶
Pull the two old brake pads out of both the front and rear of the pad bracket. Pull the two old brake pads out of both the front and rear of the pad bracket.
단계 5  ¶
  • Pull the two old brake pads out of both the front and rear of the pad bracket.
단계 6  ¶
Inspect the brake pad wear sensor on the old brake pad. The sensor is a metallic tab attached to the brake pad. When the brake pads wear down too much, the metallic tab contacts the rotor and makes a screeching sound.
단계 6  ¶
  • Inspect the brake pad wear sensor on the old brake pad. The sensor is a metallic tab attached to the brake pad. When the brake pads wear down too much, the metallic tab contacts the rotor and makes a screeching sound.
단계 7  ¶
Place the new brake pads into the bracket. Make sure that the new pads are secure.
단계 7  ¶
  • Place the new brake pads into the bracket. Make sure that the new pads are secure.
단계 8  ¶
The new brake pads are thicker than the old pads. Because of this, the caliper piston protrudes too far out to allow enough clearance for the caliper to be placed over the new pads. You will need to manually retract the caliper piston.
단계 8  ¶
  • The new brake pads are thicker than the old pads. Because of this, the caliper piston protrudes too far out to allow enough clearance for the caliper to be placed over the new pads. You will need to manually retract the caliper piston.
  • To do this, place an old brake pad over the caliper piston.
단계 9  ¶
Place one end of the c-clamp jaw over the old pad. Place the other end of the jaw on the rear of the caliper. Tighten the c-clamp to push the piston back into the caliper. This will push oil back into the brake reservoir, which could overflow. This can be wasteful, messy, and damage your car's paint job. Make sure the reservoir isn't topped off. It is also a good idea to remove the cap from the reservoir before retracting the piston. The reservoir is located under the hood and should be clearly labeled.
단계 9  ¶
  • Place one end of the c-clamp jaw over the old pad. Place the other end of the jaw on the rear of the caliper. Tighten the c-clamp to push the piston back into the caliper.
  • This will push oil back into the brake reservoir, which could overflow. This can be wasteful, messy, and damage your car's paint job. Make sure the reservoir isn't topped off. It is also a good idea to remove the cap from the reservoir before retracting the piston. The reservoir is located under the hood and should be clearly labeled.
단계 10  ¶
Slide the caliper over the brake pad bracket with the new brake pads. If you removed the cap from the brake fluid reservoir replace it as soon as the brake caliper piston has been retracted. Do not leave the cap off any longer than absolutely necessary.
단계 10  ¶
  • Slide the caliper over the brake pad bracket with the new brake pads.
  • If you removed the cap from the brake fluid reservoir replace it as soon as the brake caliper piston has been retracted. Do not leave the cap off any longer than absolutely necessary.
단계 11  ¶
To reassemble the wheel assembly. Follow the Steps 1-7 in reverse order.
단계 11  ¶
  • To reassemble the wheel assembly. Follow the Steps 1-7 in reverse order.
  • The caliper mounting bolts and the lug nuts must be tightened to the correct torque value, using a torque wrench. The values may differ depending on your car's configuration and options, but are typically listed as:
  • Caliper bolts: 54 ft lbs
  • Lug nuts: 80 ft lbs
  • Remove the jack stand. Then lower and remove the floor jack.
  • CAUTION! : Before driving the car, pump the brake pedal several times in order to push the caliper piston back against the brake pads. If this step is not performed, the car may not brake reliably when first driven. For your safety, this step is essential.
