메인 콘텐츠로 스킵하기
도움말
iMac Intel 20" EMC 2105 and 2118 Heat Sinks Replacement
Use this guide to replace your heat sinks.
단계 1 Heat Sinks  ¶
Remove the 6.1 mm T8 Torx screw from both sides of the heat sink nearest the logic board (two screws total).
단계 1 Heat Sinks  ¶
  • Remove the 6.1 mm T8 Torx screw from both sides of the heat sink nearest the logic board (two screws total).
단계 2  ¶
Remove the following ten screws: Eight 7.8 mm T8 Torx.
단계 2  ¶
  • Remove the following ten screws:
  • Eight 7.8 mm T8 Torx.
  • Two 6.1 mm T8 Torx.
  • If the eight screws around the processors refuse to unscrew, use a Phillips screwdriver to hold the lug from the one side of the board while you remove the Torx screw from the other side.
단계 3  ¶
Carefully lift both metal heat sink brackets off the logic board. Carefully lift both metal heat sink brackets off the logic board.
단계 3  ¶
  • Carefully lift both metal heat sink brackets off the logic board.
단계 4  ¶
Lift the logic board off the heat sinks.
단계 4  ¶
  • Lift the logic board off the heat sinks.
  • If a heat sink seems to be stuck, carefully pry it away from the logic board to separate the solidified thermal paste.
  • If you need to mount the heat sink back into the iMac, we have a thermal paste guide that makes replacing the thermal compound easy.
  • During reinstallation it is helpful to install the heat sinks one at a time, starting with the one closest to the logic board.
