도움말
Engine Cover
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
Remove the engine cover. Necessary for servicing the gas tank, flywheel, starting cord, and other parts.
단계 1 Remove covers  ¶
Remove 2 Phillips screws holding the plastic engine shroud. Pull the cover up and off the engine. Remove 3 bolts with a 5/16 socket, then pull the plastic cover off the engine Remove 3 bolts with a 5/16 socket, then pull the plastic cover off the engine
  • Remove 2 Phillips screws holding the plastic engine shroud. Pull the cover up and off the engine.
  • Remove 3 bolts with a 5/16 socket, then pull the plastic cover off the engine
