메인 콘텐츠로 스킵하기
도움말
Nostalgia Electrics RHP-310 Replacing Fan Replacement
글머리 기호!
글머리 기호!
더 나은 마크업 및 글머리 기호 색/형식 조정은 해당 안내서를 더욱 깔끔하게 만들것 입니다!
헷갈리는 텍스트
헷갈리는 텍스트
해당 안내서의 어떤 텍스트는 헷갈리며, 중복되었거나 주제에서 벗어났습니다. 편집하여 명확하게 하여 주십시오!
Use this guide to replace the fan inside the popper.
  • 작성자: Dana Clarke
  • 예상 시간 20 - 25 분
  • 난이도: 보통
This guide will outline how to replace the fan inside the heating component.
단계 1 Replacing Fan  ¶
Now that the white top is disconnected from the housing, remove the heating component from inside the device.
  • Now that the white top is disconnected from the housing, remove the heating component from inside the device.
단계 2  ¶
Unscrew the three screws (10 mm Philips #2 screws) that hold the heating component together.
단계 2  ¶
  • Unscrew the three screws (10 mm Philips #2 screws) that hold the heating component together.
단계 3  ¶
Make sure to keep the screws.  You will need them to put the heating component back together.
단계 3  ¶
  • Make sure to keep the screws. You will need them to put the heating component back together.
  • Pull the heating component apart.
단계 4  ¶
Locate the fan. Pull the fan off the motor firmly but gently.
단계 4  ¶
  • Locate the fan.
  • Pull the fan off the motor firmly but gently.
  • When you pull the fan off the motor, be careful. Do not pull to hard or you will break the motor.
단계 5  ¶
You can now replace the fan.
단계 5  ¶
  • You can now replace the fan.
  • If there is debris stuck in the fan, you can easily clean it out from the fan in this step.
