메인 콘텐츠로 스킵하기
도움말
Removing Fender Frontman 15r Back panel
  • 작성자: Greg Sawers
  • 예상 시간 5 분
  • 난이도: 쉬움
Need to get inside the amp? Remove the back panel!
단계 1 Back panel  ¶
Be sure to unplug the device before proceeding.
단계 1 Back panel  ¶
  • Be sure to unplug the device before proceeding.
  • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
단계 2  ¶
Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
단계 2  ¶
  • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
단계 3  ¶
Once the top is separated, use your hand to remove the back panel from the unit.
단계 3  ¶
  • Once the top is separated, use your hand to remove the back panel from the unit.
