도움말
Kenmore 110 Series Washing Machine Electronic Control Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
글머리 기호!
글머리 기호!
더 나은 마크업 및 글머리 기호 색/형식 조정은 해당 안내서를 더욱 깔끔하게 만들것 입니다!
한 단계 누락
한 단계 누락
이런! 해당 안내서는 현재 몇몇 중요한 단계가 빠져 있습니다.
Replace a faulty electronic control on your Kenmore 110 Washing Machine.
  • 작성자: Robert Trout
  • 예상 시간 15 - 30 분
  • 난이도: 보통
Use this guide to replace a faulty electronic control on your Kenmore 110 Washing Machine.
단계 1 Electronic Control  ¶
Unplug the washing machine!
  • Unplug the washing machine!
  • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
  • Lifting from the rear, remove the top panel.
  • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
단계 2  ¶
Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover. From the bottom, pull out and remove the component cover. From the bottom, pull out and remove the component cover.
단계 2  ¶
  • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
  • From the bottom, pull out and remove the component cover.
단계 3  ¶
Carefully remove the three wire harnesses. With a phillips head screwdriver, remove the three mounting screws.
단계 3  ¶
  • Carefully remove the three wire harnesses.
  • With a phillips head screwdriver, remove the three mounting screws.
