메인 콘텐츠로 스킵하기
도움말
Kenmore 110 Series Washing Machine Water Pump Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
Replace a faulty water pump on your Kenmore 110 Series Washing Machine.
  • 작성자: Robert Trout
  • 예상 시간 15 - 30 분
  • 난이도: 보통
Use this guide to replace a faulty water pump on your Kenmore 110 Series Washing Machine.
단계 1 Water Pump  ¶
Unplug the washing machine!
단계 1 Water Pump  ¶
  • Unplug the washing machine!
  • Carefully lay washing machine on its back.
단계 2  ¶
Carefully remove both wire harnesses connected to the pump. Squeeze and pull back hose clamp. Twist drain hose off of pump.
단계 2  ¶
  • Carefully remove both wire harnesses connected to the pump.
  • Squeeze and pull back hose clamp.
  • Twist drain hose off of pump.
  • Using a 1/4" socket wrench, remove the three mounting screws.
  • Pull the pump out of place.
  • Pulling the pump away takes a little force.
