도움말
Blackberry DTek 60 Battery Replacement
진행 중
진행 중
해당 안내서는 작업중 입니다. 최근 변경사항을 보려면 정기적으로 새로고침하여 주십시오!
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
Teach you to remove the back glass, and replace the battery.
  • 작성자: Scott
  • 예상 시간 30 분
  • 난이도: 보통
단계 1 Detatch The Back Glass  ¶
Apply heat to the back glass around the edges. you can do this by one of three ways. 1) the iOpener Tool, 2) the hot air gun, and 3) the mobile dryer. Lift the corner as much as possible. Should there be any excessive resistance, be sure to apply more heat. begin working your way through the panel seam. should you encounter and snags, be sure ti dab a minimal amount of alcohal onto your pick, and that will help eat away at the adhesive
  • Apply heat to the back glass around the edges. you can do this by one of three ways. 1) the iOpener Tool, 2) the hot air gun, and 3) the mobile dryer.
  • Lift the corner as much as possible. Should there be any excessive resistance, be sure to apply more heat.
  • begin working your way through the panel seam. should you encounter and snags, be sure ti dab a minimal amount of alcohal onto your pick, and that will help eat away at the adhesive
단계 2 Remove the Back Panel  ¶
when there is enough glass Separating, begin to lift it slowly. There is a cable connecting your finger print sensor to the board. BE SURE NOT TO TEAR THIS
  • when there is enough glass Separating, begin to lift it slowly. There is a cable connecting your finger print sensor to the board. BE SURE NOT TO TEAR THIS
  • Lift from the left side to prevent damage to the sensor, and disconnect the connector from the board.
단계 3 Lift The Battery  ¶
Disconnect the battery from the board, and Reheat the location to losen adhesive.
  • Disconnect the battery from the board, and Reheat the location to losen adhesive.
  • Try not to directly heat the battery. if you heat a bad battery, the Lithium may expand and cause damage to the board or self.
  • Gently lift the battery from the housing. The adhesive is tough, and may require some force. dont puncture the battery while doing this.
단계 4 Close Device  ¶
없는 이미지
단계 4 Close Device  ¶
  • Follow the steps in reverse to reassemble the device.
  • Congratulations on your new battery
