도움말
Mac mini Model A1176 RAM Replacement
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
  • 작성자: Walter Galan
  • 예상 시간 30 분
  • 난이도: 보통
Accessing the RAM requires the removal of the internal frame.
단계 1 RAM  ¶
Simultaneously pull the tabs on each side of the RAM chip away from the center of the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. Simultaneously pull the tabs on each side of the RAM chip away from the center of the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
단계 1 RAM  ¶
  • Simultaneously pull the tabs on each side of the RAM chip away from the center of the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
단계 2  ¶
Pull the RAM chip directly out from its connector.
단계 2  ¶
  • Pull the RAM chip directly out from its connector.
  • If there are two RAM chips installed, repeat the above procedure for the second chip.
