메인 콘텐츠로 스킵하기
도움말
GD Midea FT30-3D Fan Blades Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
How to replace the fan blades if they are damaged.
  • 작성자: Alan Su
  • 예상 시간 5 - 10 분
  • 난이도: 쉬움
단계 1 Fan Blades  ¶
Release the 3 clips that attach the front fan guard to the rear fan guard. Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
단계 1 Fan Blades  ¶
  • Release the 3 clips that attach the front fan guard to the rear fan guard.
  • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
단계 2  ¶
Pull the front fan guard off.
단계 2  ¶
  • Pull the front fan guard off.
단계 3  ¶
Remove the spinner from the center of the fan blade. Remove the spinner from the center of the fan blade.
단계 3  ¶
  • Remove the spinner from the center of the fan blade.
단계 4  ¶
The fan blades should now be easy to lift up.
단계 4  ¶
  • The fan blades should now be easy to lift up.
  • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
