도움말
기술: Repairing Quasar Microwave Fan
잠재적으로 위험한
잠재적으로 위험한
절차를 제대로 따르지 않을 경우 부상을 입을 수 있습니다. 주의를 요하며 모든 경고를 따라주십시오.
잠재적으로 치명적인
잠재적으로 치명적인
해당 안내서를 제대로 따르지 않을 경우 사망 또는 절단사고를 당할 수 있습니다. 각별한 주의를 요하며 모든 경고를 따라주십시오!
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
This guide will describe various ways to fix the microwaves fan if it is no longer spinning.
  • 작성자: Melanie
  • 난이도: 보통
단계 1 Repairing Quasar Microwave Fan  ¶
Locate the fan in the newly exposed interior. Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
  • Locate the fan in the newly exposed interior.
  • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
  • If the fan does not spin freely, locate what is jamming the fan and remove it.
단계 2  ¶
If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
단계 2  ¶
  • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
  • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
