메인 콘텐츠로 스킵하기
도움말
HP Photosmart c4780 Motherboard Replacement
잘게 썰기
잘게 썰기
해당 안내서의 단계들은 분할되어 전제 조건 안내서들로 만들어져야 합니다.
This guide is to aid in the removal of the HP Photosmart c4780 motherboard.
  • 작성자: garrett hall
  • 예상 시간 4 - 10 분
  • 난이도: 보통
After completing the Outer Shell Disassembly guide, this process will aid in replacing the HP Photosmart c4780 motherboard with minimal technical requirements.
단계 1 Motherboard  ¶
Remove the three uncovered T10 screws from the motherboard.
단계 1 Motherboard  ¶
  • Remove the three uncovered T10 screws from the motherboard.
단계 2  ¶
Gently remove the seven cables that are attached to the motherboard using a plastic opening tool.
단계 2  ¶
  • Gently remove the seven cables that are attached to the motherboard using a plastic opening tool.
단계 3  ¶
Gently lift motherboard out of the slot.
단계 3  ¶
  • Gently lift motherboard out of the slot.
