메인 콘텐츠로 스킵하기
도움말
Samsung Galaxy Tab 4 10.1 Motherboard Replacement
This free guide will show you how to replace the motherboard on a Samsung Galaxy Tab 4 10.1 tablet.
  • 작성자: Blake Klein
  • 예상 시간 40 분 - 1 시간
  • 난이도: 보통
Replacement guide for the motherboard on a Samsung Galaxy Tab 4 10.1 android tablet.
단계 1 Motherboard  ¶
Remove the two 2.7mm Phillips #00 screws from the motherboard. Remove the two 2.7mm Phillips #00 screws from the motherboard.
단계 1 Motherboard  ¶
  • Remove the two 2.7mm Phillips #00 screws from the motherboard.
단계 2  ¶
Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard. Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard.
단계 2  ¶
  • Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard.
단계 3  ¶
Use a spudger to pry up the motherboard, and remove it from the device. Use a spudger to pry up the motherboard, and remove it from the device.
단계 3  ¶
  • Use a spudger to pry up the motherboard, and remove it from the device.
