도움말
기술: IDN Poker Indonesia
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
Mc88poker adalah Daftar Poker Terpercaya, Situs Judi Online, IDN Poker Indonesia yang menyediakan permainan judi kartu Terbaik dan Teraman.
  • 작성자: Noah
  • 예상 시간 15 분
  • 난이도: 쉬움
Mc88poker adalah Daftar Poker Terpercaya, Situs Judi Online, IDN Poker Indonesia yang menyediakan permainan judi kartu Terbaik dan Teraman. MC88Poker merupakan situs judi yang menyediakan banyak pilihan permainan judi Kartu yang dapat anda nikmati secara online di Indonesia. Beberapa jenis permainan yang dapat anda mainkan disini adalah Poker Online, Domino QQ, Ceme, Ceme Keliling, Capsa dan Omaha. Pilihan permainan ini dapat anda akses dengan sangat mudah. Cukup dengan lakukan daftar poker dan gunakan User ID yang anda dapatkan untuk bermain di banyak permainan yang tersedia di Mc88poker.
단계 1 IDN Poker Indonesia  ¶
Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner. Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
  • Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner.
  • Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
  • Start the engine
단계 2  ¶
Allow time for the engine to warm up completely Attach carburetor synchronization tool to  one of the carburetors
단계 2  ¶
  • Allow time for the engine to warm up completely
  • Attach carburetor synchronization tool to one of the carburetors
  • Observe the relative reading, and remember it.
  • This reading is a measurement of the airflow speed
단계 3  ¶
Set the  synchronization device on the other carburetor.
단계 3  ¶
  • Set the synchronization device on the other carburetor.
  • Using a Flathead screw-driver, twist the idle speed screw in to raise the flow, and out to lower it.
  • Recheck both carburetors and adjust as needed to get the flow as equal as possible.
단계 4  ¶
Now, the idle mixture screws must be adjusted. It is important that when the screws are adjusted they are adjusted the same amount in the same direction.
단계 4  ¶
  • Now, the idle mixture screws must be adjusted.
  • It is important that when the screws are adjusted they are adjusted the same amount in the same direction.
  • Turn both screws in, or out an 1/8 or a turn at a time until the fastest idle speed is achieved.
  • Before proceeding with this step you should have already checked your ignition timing, if you have not do it now, and then continue from here.
단계 5  ¶
Finally, raise or lower the idle speed screws until the idle speed is about 550 RPM
단계 5  ¶
  • Finally, raise or lower the idle speed screws until the idle speed is about 550 RPM
  • Once more, it is important to adjust the screws the same amount.
  • Rotate the aircleaner back to its original position, and re-tighten the 3/8 nuts on the retainers
