도움말
HP Mini 210 RAM Replacement
한 단계 누락
한 단계 누락
이런! 해당 안내서는 현재 몇몇 중요한 단계가 빠져 있습니다.
Replace your RAM (random access memory) module if it malfunctions or if you want to upgrade the memory.
Installing new RAM (random access memory) on your netbook is quick and requires little disassembly.
단계 1 RAM  ¶
Push out the two plastic prongs on either side of the RAM.
단계 1 RAM  ¶
  • Push out the two plastic prongs on either side of the RAM.
단계 2  ¶
The RAM should pop up allowing for easy removal from its compartment.
단계 2  ¶
  • The RAM should pop up allowing for easy removal from its compartment.
  • Pull out the RAM.
