메인 콘텐츠로 스킵하기
도움말
CygoLite Night Rover Light Bulb Replacement
일관성 없는 이미지
일관성 없는 이미지
해당 안내서의 이미지를 전제 조건들과 더욱 일관성 있게 업데이트하는 것은 안내서의 멋짐이 향상될 것입니다.
This guide provides instructions on how to replace the light bulbs in the CygoLite Night Rover.
  • 작성자: Kelly
  • 예상 시간 15 분
  • 난이도: 쉬움
The light bulbs on the device are prone to breakage and burn out. This guide provides information on how to replace the light bulbs.
단계 1 Light Bulb  ¶
Place the device with the bottom facing upwards. Using a Phillips head screwdriver remove the screws on the bottom of the device.
단계 1 Light Bulb  ¶
  • Place the device with the bottom facing upwards.
  • Using a Phillips head screwdriver remove the screws on the bottom of the device.
단계 2  ¶
Flip the device so that the top is facing upwards. Lift the top casing to expose the light. Lift the top casing to expose the light.
단계 2  ¶
  • Flip the device so that the top is facing upwards.
  • Lift the top casing to expose the light.
단계 3  ¶
Remove light out of the socket. Remove light out of the socket. Remove light out of the socket.
단계 3  ¶
  • Remove light out of the socket.
단계 4  ¶
Obtain a replacement bulb and plug it into the empty socket. Obtain a replacement bulb and plug it into the empty socket. Obtain a replacement bulb and plug it into the empty socket.
단계 4  ¶
