도움말
Shark Rotator Powered Lift-Away Speed Roller Brush Replacement
추천 학생 안내서
추천 학생 안내서
해당 안내서는 저희 멋진 학생들의 노력으로 만들어졌으며 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
How to change the roller brush on the Shark Rotator Powered Lift-Away Vacuum.
  • 작성자: Sujey Ruano
  • 예상 시간 1 - 2 시간
  • 난이도: 보통
The roller brush can have debris that will cause the vacuum to not work properly. It is important that you always clean your roller brush after every use, so that your Shark Rotator Powered Lift Away Speed Vacuum can perform at it's best. This guide will show you how to change your roller brush if it becomes damaged or is broken.
단계 1 Roller Brush  ¶
Pull roller brush away from the vacuum.
단계 1 Roller Brush  ¶
  • Pull roller brush away from the vacuum.
