메인 콘텐츠로 스킵하기
도움말
Hover-1 Titan Wheel and Motor Replacement
How to replace the wheel and motor on the Hover-1 Titan.
  • 작성자: Emma Huun
  • 예상 시간 15 - 40 분
  • 난이도: 보통
If the wheel of your hoverboard is damaged or your hoverboard does not spin on one side, use this guide to replace the wheel and motor in the Hover-1 Titan.
단계 1 Wheel and Motor  ¶
Unplug the battery by pulling apart the yellow connectors. Unplug the battery by pulling apart the yellow connectors.
  • Unplug the battery by pulling apart the yellow connectors.
단계 2  ¶
Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard. Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
단계 2  ¶
  • Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
단계 3  ¶
Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors. Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors. Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
단계 3  ¶
  • Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
단계 4  ¶
Unplug the yellow wires by gripping the wire close to the connectors and pulling apart. Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
단계 4  ¶
  • Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
단계 5  ¶
Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors. Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors. Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
단계 5  ¶
  • Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
단계 6  ¶
Unplug the green wires by gripping the wire close to the connectors and pulling apart. Unplug the green wires by gripping the wire close to the connectors and pulling apart.
단계 6  ¶
  • Unplug the green wires by gripping the wire close to the connectors and pulling apart.
단계 7  ¶
Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors. Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors. Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
단계 7  ¶
  • Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
단계 8  ¶
Unplug the blue wires by gripping the wire close to the connectors and pulling apart. Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
단계 8  ¶
  • Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
단계 9  ¶
Unplug the rainbow connector by squeezing the clips and pulling apart. Unplug the rainbow connector by squeezing the clips and pulling apart. Unplug the rainbow connector by squeezing the clips and pulling apart.
단계 9  ¶
  • Unplug the rainbow connector by squeezing the clips and pulling apart.
단계 10  ¶
Use scissors to cut the zip tie around the group of wires. Use scissors to cut the zip tie around the group of wires.
단계 10  ¶
  • Use scissors to cut the zip tie around the group of wires.
단계 11  ¶
Unplug the white wire connector by squeezing the clips and pulling apart. Unplug the white wire connector by squeezing the clips and pulling apart. Unplug the white wire connector by squeezing the clips and pulling apart.
단계 11  ¶
  • Unplug the white wire connector by squeezing the clips and pulling apart.
단계 12  ¶
Use an impact driver with a hex 6 bit to loosen the four 20 mm hex 6 bolts. Wear safety glasses while using the impact driver.
단계 12  ¶
  • Use an impact driver with a hex 6 bit to loosen the four 20 mm hex 6 bolts.
  • Wear safety glasses while using the impact driver.
단계 13  ¶
Pull out the loosened screws with your hands and remove the metal plate. Pull out the loosened screws with your hands and remove the metal plate. Pull out the loosened screws with your hands and remove the metal plate.
단계 13  ¶
  • Pull out the loosened screws with your hands and remove the metal plate.
단계 14  ¶
Lift the wheel and motor shaft up and out of the board. The motor shaft is located within the wheel.
단계 14  ¶
  • Lift the wheel and motor shaft up and out of the board.
  • The motor shaft is located within the wheel.
