도움말
Casio CTK-501 Battery Connection Replacement
한 단계 누락
한 단계 누락
이런! 해당 안내서는 현재 몇몇 중요한 단계가 빠져 있습니다.
헷갈리는 텍스트
헷갈리는 텍스트
해당 안내서의 어떤 텍스트는 헷갈리며, 중복되었거나 주제에서 벗어났습니다. 편집하여 명확하게 하여 주십시오!
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
If the battery area has been damaged you might have to repair the connection to the circuit board that collects all the power for the keyboard.
단계 1 Battery Connection  ¶
Plug in the soldering iron and set it somewhere safe where it can't catch anything on fire.
  • Plug in the soldering iron and set it somewhere safe where it can't catch anything on fire.
  • Unscrew the top green circuit board with black and red wires running into it.
단계 2  ¶
Set the circuit board somewhere flat so it is safe to solder.
단계 2  ¶
  • Set the circuit board somewhere flat so it is safe to solder.
단계 3  ¶
Heat up the solder covering the end of the wires connected to the circuit board.  Once the solder melts, remove the wires from the circuit board.
단계 3  ¶
  • Heat up the solder covering the end of the wires connected to the circuit board. Once the solder melts, remove the wires from the circuit board.
단계 4  ¶
Melt new solder with your soldering iron, then apply it over the tip of the wire touching the circuit board.
단계 4  ¶
  • Melt new solder with your soldering iron, then apply it over the tip of the wire touching the circuit board.
단계 5  ¶
Once the wires are firmly attached screw the circuit board back onto the keyboard.
단계 5  ¶
  • Once the wires are firmly attached screw the circuit board back onto the keyboard.
