도움말
기술: How to repair Tractor or Motorcycle CDI
진행 중
진행 중
해당 안내서는 작업중 입니다. 최근 변경사항을 보려면 정기적으로 새로고침하여 주십시오!
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
This guide shows how to repair a failed capacitor discharge ignition also known as a CDI.
  • 작성자: John Painter
  • 예상 시간 1 시간
  • 난이도: 보통
This technique should only be used once you have positively identified the reason your tractor or motorcycle, scooter, etc is not starting, or not starting reliably. Though in my experience this repair works the vast majority of the time, there are times when it might not work due to failure of components in the CDI versus cold solder failure. If you have about an hour, patience and basic soldering skills this is an excellent option to try and resurrect a failed CDI!
