도움말
Giant Reign 2 Headset Replacement
더 많은 이미지가 필요함
더 많은 이미지가 필요함
몇몇 추가 이미지는 해당 안내서의 절차를 아주 명백하게 만들 것입니다.
This guide tells you exactly how to install and lubricate a new headset for the Giant Reign 2 bicycle.
Proper maintenance of the Giant Reign 2 bicycle includes installation and lubrication of a new headset. This guide will clearly show you how to perform this maintenance quickly and safely, extending the life of your bike.
단계 1 Headset  ¶
Using the 8mm Allen wrench, unscrew 2  (32mm) screws to release the brake calipers from the fork. If necessary use wire cutters to release zip ties attaching cables to the forks.
단계 1 Headset  ¶
  • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
  • If necessary use wire cutters to release zip ties attaching cables to the forks.
단계 2  ¶
Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam. Using the 4mm Allen wrench, loosen the side screw on both sides. Lift off the handlebar.
단계 2  ¶
  • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
  • Using the 4mm Allen wrench, loosen the side screw on both sides.
  • Lift off the handlebar.
  • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
단계 3  ¶
Slide off the spacers. Lift off the seal. Lift off the seal.
단계 3  ¶
  • Slide off the spacers.
  • Lift off the seal.
단계 4  ¶
Slide the fork out of the casing.
단계 4  ¶
  • Slide the fork out of the casing.
단계 5  ¶
Using your fingers, pry the bearings from the top and bottom of the headset.
단계 5  ¶
  • Using your fingers, pry the bearings from the top and bottom of the headset.
단계 6  ¶
Apply WD-40 to both ends of the headset and bearings.
단계 6  ¶
  • Apply WD-40 to both ends of the headset and bearings.
  • Dry headset and bearings with paper towels.
  • Repeat as necessary until clean.
단계 7  ¶
Using your finger, apply all-purpose lube to the bearings and each end of the headset. Insert the bearings into the headset with the beveled side facing into the headset.
단계 7  ¶
  • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
  • Insert the bearings into the headset with the beveled side facing into the headset.
