도움말
ASUS G73JH-BST7 Back Panel Replacement
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
This guide will advise the operator on the removal of the back panel on the ASUS G73JH-BST7.
단계 1 Back Panel  ¶
With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver. With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver. With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
단계 1 Back Panel  ¶
  • With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
단계 2  ¶
Carefully pry the panel away from the computer, by lifting with a finger. There is a small tab where a finger will fit to lift the panel away from the computer. There is a small tab where a finger will fit to lift the panel away from the computer.
단계 2  ¶
  • Carefully pry the panel away from the computer, by lifting with a finger.
  • There is a small tab where a finger will fit to lift the panel away from the computer.
