메인 콘텐츠로 스킵하기
도움말
Motorola Droid X Rear Case Replacement
These are instructions on how to remove the rear case of a Motorola Droid X.
  • 작성자: Anna
  • 난이도: 보통
단계 1 Rear Case  ¶
Objective: remove the rear case from the Motorola Droid X phone.
단계 1 Rear Case  ¶
  • Objective: remove the rear case from the Motorola Droid X phone.
  • This is what the Motorola Droid X looks like before disassembly. In the front, there is a large LCD touch screen.
단계 2  ¶
INSTRUCTION: Turn the phone over so that the back faces up.
단계 2  ¶
  • INSTRUCTION: Turn the phone over so that the back faces up.
단계 3  ¶
Objective: remove the battery casing plate.
단계 3  ¶
  • Objective: remove the battery casing plate.
  • The case plate has a push and slide mechanism.
단계 4  ¶
INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
단계 4  ¶
  • INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
  • INSTRUCTION 2: Slide down the battery case plate.
단계 5  ¶
INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
단계 5  ¶
  • INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
단계 6  ¶
Objective: remove the battery from the battery compartment.
단계 6  ¶
  • Objective: remove the battery from the battery compartment.
단계 7  ¶
INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
단계 7  ¶
  • INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
단계 8  ¶
Objective:  remove two small black screws from the back of the phone.
단계 8  ¶
  • Objective: remove two small black screws from the back of the phone.
  • These two (2) screws help hold the phone together. They need to be removed by a Phillips Hex 2mm screwdriver,
단계 9  ¶
INSTRUCTION: Remove two black screws from the back of the phone.
단계 9  ¶
  • INSTRUCTION: Remove two black screws from the back of the phone.
단계 10  ¶
Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
단계 10  ¶
  • Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
  • The two plastic pieces are clipped onto the phone as covers. They are located at the top and the bottom of the phone.
단계 11  ¶
INSTRUCTION: Flip the phone over to the front side.
단계 11  ¶
  • INSTRUCTION: Flip the phone over to the front side.
단계 12  ¶
INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone.  It will pop off.
단계 12  ¶
  • INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone. It will pop off.
단계 13  ¶
INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
단계 13  ¶
  • INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
단계 14  ¶
Objective: remove four white screws from the corners of the screen.
단계 14  ¶
  • Objective: remove four white screws from the corners of the screen.
  • These four (4) screws help hold the phone together. Use a Phillips Hex 2mm screwdriver
단계 15  ¶
INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
단계 15  ¶
  • INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
단계 16  ¶
INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
단계 16  ¶
  • INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
단계 17  ¶
Objective: remove the rear case from the phone in order to provide access to inside the phone.
단계 17  ¶
  • Objective: remove the rear case from the phone in order to provide access to inside the phone.
  • The phone is now held together by the casing alone. You need to pop the two halves apart.
단계 18  ¶
INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the  casing. They will pop apart.
단계 18  ¶
  • INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the casing. They will pop apart.
단계 19  ¶
Now you are ready to access the internal circuits of the phone.
단계 19  ¶
  • Now you are ready to access the internal circuits of the phone.
