도움말
WowWee CHiP Robot Dog Ear Replacement
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
How to disassemble CHiP to replace ear.
  • 작성자: Joseph Dantes
  • 예상 시간 10 - 20 분
  • 난이도: 어려움
단계 1 Ear  ¶
Remove the 4 Phillips screws shown. Remove the 4 Phillips screws shown.
단계 1 Ear  ¶
  • Remove the 4 Phillips screws shown.
단계 2  ¶
Pull up top part of toy and remove the connecting wires. Unscrew the 2 Phillips head screws. CHiP should be viewed as seen in the third picture. Unscrew the 2 Phillips head screws. CHiP should be viewed as seen in the third picture.
단계 2  ¶
  • Pull up top part of toy and remove the connecting wires.
  • Unscrew the 2 Phillips head screws. CHiP should be viewed as seen in the third picture.
단계 3  ¶
Remove the 4 Phillips screws to separate the head from the body. Remove the 4 Phillips screws to separate the head from the body. Remove the 4 Phillips screws to separate the head from the body.
단계 3  ¶
  • Remove the 4 Phillips screws to separate the head from the body.
단계 4  ¶
Remove the 4 Phillips screws on back of the head, and pull off the casing for the back of the head. Remove the 4 Phillips screws on back of the head, and pull off the casing for the back of the head.
단계 4  ¶
  • Remove the 4 Phillips screws on back of the head, and pull off the casing for the back of the head.
단계 5  ¶
Unscrew the screw on the ear with a Phillips screwdriver, and pull off the plastic connector. Remove the ear from head. Unscrew the screw on the ear with a Phillips screwdriver, and pull off the plastic connector. Remove the ear from head. Unscrew the screw on the ear with a Phillips screwdriver, and pull off the plastic connector. Remove the ear from head.
단계 5  ¶
  • Unscrew the screw on the ear with a Phillips screwdriver, and pull off the plastic connector. Remove the ear from head.
