메인 콘텐츠로 스킵하기
도움말
iPod Touch 5th Generation Power Button Replacement
Remove the power/sleep button from your iPod Touch 5th Generation.
Use this guide to remove the power/sleep button from your iPod Touch.
단계 1 Power Button  ¶
Remove the following screws from the button ribbon cable:
단계 1 Power Button  ¶
  • Remove the following screws from the button ribbon cable:
  • Two 2.3 mm #000 Phillips screws
  • One 1.6 mm #000 Phillips screw
단계 2  ¶
Use tweezers to remove the small metal backing plate from the power switch section of the button ribbon cable. Use tweezers to remove the small metal backing plate from the power switch section of the button ribbon cable.
단계 2  ¶
  • Use tweezers to remove the small metal backing plate from the power switch section of the button ribbon cable.
단계 3  ¶
Insert a plastic opening tool into the rear-facing camera frame and pry up against the rear case. Twist the plastic opening tool slightly counter-clockwise to pry the camera frame up from the rear case. Twist the plastic opening tool slightly counter-clockwise to pry the camera frame up from the rear case.
단계 3  ¶
  • Insert a plastic opening tool into the rear-facing camera frame and pry up against the rear case.
  • Twist the plastic opening tool slightly counter-clockwise to pry the camera frame up from the rear case.
단계 4  ¶
Use the closed tip of a pair of tweezers to push the power/sleep button into the rear case. Use tweezers to remove the power button from the iPod. Use tweezers to remove the power button from the iPod.
단계 4  ¶
  • Use the closed tip of a pair of tweezers to push the power/sleep button into the rear case.
  • Use tweezers to remove the power button from the iPod.
