도움말
iBook G3 12" Keyboard Replacement
  • 작성자: iRobot
  • 예상 시간 10 - 20 분
  • 난이도: 쉬움
Replacing this keyboard is easy and takes only a few minutes.
섹션
파일
도구
단계 1 Keyboard  ¶
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
단계 1 Keyboard  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
단계 2  ¶
If the computer does not have an Airport card installed, skip the next two steps.
단계 2  ¶
  • If the computer does not have an Airport card installed, skip the next two steps.
  • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
단계 3  ¶
Grasp the clear plastic tab on the Airport card and pull toward the right.
단계 3  ¶
  • Grasp the clear plastic tab on the Airport card and pull toward the right.
단계 4  ¶
Hold the Airport card in one hand and use your other hand to remove the antenna cable.
단계 4  ¶
  • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
단계 5  ¶
Remove the two 2.5 mm Phillips screws that secure the RAM shield.
단계 5  ¶
  • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
단계 6  ¶
Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
단계 6  ¶
  • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
단계 7  ¶
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
단계 7  ¶
  • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
