도움말
기술: Epson WF-3640 Firmware Upgrade
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
The builtin webserver in this printer will allow you to update the firmware from withing the web user interface. Normally this is easier than other methods.
  • 작성자: tcagle53
  • 예상 시간 15 분
  • 난이도: 아주 쉬움
단계 1 Make sure your printer is powered up and network connected.  ¶
You won't be able to proceed effectively if the printer can't be pinged on the network!
  • You won't be able to proceed effectively if the printer can't be pinged on the network!
  • Note: you may be able to apply these principles to many other printers whose firmwares support a web user interface. The menus will vary of course.
단계 2  ¶
Open a browser window on any device attached to your network and type in the local network address of the printer.
단계 2  ¶
  • Open a browser window on any device attached to your network and type in the local network address of the printer.
단계 3  ¶
Scroll to bottom of left panel with scroll thumb. Click on "Basic Settings" link there.
단계 3  ¶
  • Scroll to bottom of left panel with scroll thumb. Click on "Basic Settings" link there.
단계 4  ¶
Click on "Firmware Update" link.
단계 4  ¶
  • Click on "Firmware Update" link.
단계 5  ¶
Read and understand instructions before proceeding.
단계 5  ¶
  • Read and understand instructions before proceeding.
단계 6  ¶
Scroll to bottom of page to expose the "Start/Back to Main" buttons. Press "Start" if you are ready to attempt the firmware upgrade. Otherwise you can just close the browser tab/window if you have changed your plans.
단계 6  ¶
  • Scroll to bottom of page to expose the "Start/Back to Main" buttons. Press "Start" if you are ready to attempt the firmware upgrade. Otherwise you can just close the browser tab/window if you have changed your plans.
단계 7  ¶
After a few moments you will see this screen as it tests to see if your printer firmware is up to date.
단계 7  ¶
  • After a few moments you will see this screen as it tests to see if your printer firmware is up to date.
단계 8  ¶
If your system is already up to date you will see this page. Otherwise a page with your final confirmation options will be displayed, or you can close the browser session if you decide against upgrading of course. The warnings about not interrupting the upgrade will be given also. It will caution you against powering off while upgrade proceeds.
단계 8  ¶
  • If your system is already up to date you will see this page. Otherwise a page with your final confirmation options will be displayed, or you can close the browser session if you decide against upgrading of course. The warnings about not interrupting the upgrade will be given also. It will caution you against powering off while upgrade proceeds.
단계 9  ¶
When upgrade is completed your web interface will advise you that the printer is ready to be restarted or maybe it takes care of the hardware restart for you... I don't remember but it is pretty foolproof if you just follow the screen instructions the web interface provides. I have used this to revive completely dead (non-printing) printers too!
단계 9  ¶
  • When upgrade is completed your web interface will advise you that the printer is ready to be restarted or maybe it takes care of the hardware restart for you... I don't remember but it is pretty foolproof if you just follow the screen instructions the web interface provides. I have used this to revive completely dead (non-printing) printers too!
