메인 콘텐츠로 스킵하기
도움말
Microsoft Zune 30 GB LCD Replacement
일관성 없는 이미지
일관성 없는 이미지
해당 안내서의 이미지를 전제 조건들과 더욱 일관성 있게 업데이트하는 것은 안내서의 멋짐이 향상될 것입니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
Unclip the LCD screen and remove the ribbon cable that attaches the LCD to the logic board.
섹션
도구
단계 1 LCD  ¶
The LCD screen is held onto the logic board by four plastic clips. Unhook the clips with a small flathead screwdriver or your fingers. The LCD screen is held onto the logic board by four plastic clips. Unhook the clips with a small flathead screwdriver or your fingers.
단계 1 LCD  ¶
  • The LCD screen is held onto the logic board by four plastic clips. Unhook the clips with a small flathead screwdriver or your fingers.
단계 2  ¶
Gently lift the screen from the logic board.
단계 2  ¶
  • Gently lift the screen from the logic board.
  • Take caution when disconnecting the LCD screen from the logic board-it is connected by a ribbon cable underneath the screen.
단계 3  ¶
The LCD ribbon cable is clamped in place. Pry up the black tab on the clamp with a small flathead screwdriver or spudger.
단계 3  ¶
  • The LCD ribbon cable is clamped in place.
  • Pry up the black tab on the clamp with a small flathead screwdriver or spudger.
  • The LCD screen can now be removed.
