메인 콘텐츠로 스킵하기
도움말
iPad Mini CDMA Battery Replacement
Replace the Battery in your iPad Mini CDMA.
  • 작성자: Walter Galan
  • 예상 시간 2 시간
  • 난이도: 어려움
Use this guide to replace the battery.
단계 1 Battery  ¶
Reheat the iOpener in the microwave for one minute. Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than one minute.
단계 1 Battery  ¶
  • Reheat the iOpener in the microwave for one minute.
  • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than one minute.
  • Place the heated iOpener on the back of the iPad, along the center. Let it sit there for 90 seconds to soften the battery adhesive.
  • Move the iOpener to the right of the back of the iPad (the side opposite the rear-facing camera), and let the iOpener sit for another 90 seconds.
  • If the iOpener cools significantly between sittings, reheat it for another minute.
단계 2  ¶
Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad, to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals. Flip the iPad back over and insert a plastic card between the top left battery and the rear case.
단계 2  ¶
  • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad, to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
  • Flip the iPad back over and insert a plastic card between the top left battery and the rear case.
  • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
단계 3  ¶
Press the card in further, breaking as much of the adhesive holding in the battery as you can. Press the card in further, breaking as much of the adhesive holding in the battery as you can.
단계 3  ¶
  • Press the card in further, breaking as much of the adhesive holding in the battery as you can.
단계 4  ¶
Remove the plastic card and reinsert it underneath the top right corner of the battery. Remove the plastic card and reinsert it underneath the top right corner of the battery.
단계 4  ¶
  • Remove the plastic card and reinsert it underneath the top right corner of the battery.
단계 5  ¶
Again, press the card in further, to break more of the adhesive behind the battery. Leave this card in place to prevent the adhesive from resetting.
단계 5  ¶
  • Again, press the card in further, to break more of the adhesive behind the battery.
  • Leave this card in place to prevent the adhesive from resetting.
단계 6  ¶
Insert a second plastic card beneath the bottom left corner of the battery. Insert a second plastic card beneath the bottom left corner of the battery.
단계 6  ¶
  • Insert a second plastic card beneath the bottom left corner of the battery.
단계 7  ¶
Slowly push the card in further, breaking more of the adhesive between the battery and the rear case. Slowly push the card in further, breaking more of the adhesive between the battery and the rear case.
단계 7  ¶
  • Slowly push the card in further, breaking more of the adhesive between the battery and the rear case.
단계 8  ¶
Remove the card and reinsert it, beneath the bottom right corner of the battery. Remove the card and reinsert it, beneath the bottom right corner of the battery.
단계 8  ¶
  • Remove the card and reinsert it, beneath the bottom right corner of the battery.
단계 9  ¶
Push the card further underneath the battery. Push the card further underneath the battery.
단계 9  ¶
  • Push the card further underneath the battery.
단계 10  ¶
Grasp both cards and slowly pull the right side of the battery up about two inches from the rear case. Peel slowly and try to keep the battery as straight as possible.
단계 10  ¶
  • Grasp both cards and slowly pull the right side of the battery up about two inches from the rear case.
  • Peel slowly and try to keep the battery as straight as possible.
단계 11  ¶
While lifting the right side of the battery up with one hand, use a plastic card to cut any adhesive still holding the battery down to the rear case.
단계 11  ¶
  • While lifting the right side of the battery up with one hand, use a plastic card to cut any adhesive still holding the battery down to the rear case.
단계 12  ¶
Lift and remove the battery from the iPad. Lift and remove the battery from the iPad. Lift and remove the battery from the iPad.
단계 12  ¶
  • Lift and remove the battery from the iPad.
