메인 콘텐츠로 스킵하기
도움말
Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement
Replace the Headphone Jack/Speaker Assembly in your Samsung Galaxy S III.
  • 작성자: Walter Galan
  • 예상 시간 15 - 30 분
  • 난이도: 보통
Use this guide to replace the headphone jack/speaker assembly.
단계 1 Headphone Jack/Speaker Assembly  ¶
Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard. Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
  • Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
  • Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
단계 2  ¶
Insert a plastic opening tool outboard of the speaker portion of the headphone jack/speaker assembly. Gently pry the headphone jack/speaker assembly up from the front assembly.
단계 2  ¶
  • Insert a plastic opening tool outboard of the speaker portion of the headphone jack/speaker assembly.
  • Gently pry the headphone jack/speaker assembly up from the front assembly.
단계 3  ¶
Lift the headphone jack/speaker assembly out of the Galaxy S III.
단계 3  ¶
  • Lift the headphone jack/speaker assembly out of the Galaxy S III.
