도움말
Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement
If the Headphone Jack or Ear Speaker on your phone isn't working and you have tried everything else. You may want to try replacing the jack and speaker to solve the problem.
  • 작성자: Taylor Catlin
  • 예상 시간 15 - 20 분
  • 난이도: 보통
This guide will take you through all the steps required to access and replace the Headphone Jack and Ear Speaker on your Samsung Galaxy S Vibrant. In order to replace the jack and speaker, you fist will have to remove the battery, the inner back panel, the antenna, and the motherboard.
단계 1 Headphone Jack/Ear Speaker  ¶
Locate the three snap on ribbon cable connectors on the motherboard. Carefully disconnect the ribbon cable connectors using the Plastic Opening Tools.
  • Locate the three snap on ribbon cable connectors on the motherboard.
  • Carefully disconnect the ribbon cable connectors using the Plastic Opening Tools.
단계 2  ¶
With the three ribbon cable connectors detached, the motherboard can be folded over to the left.
단계 2  ¶
  • With the three ribbon cable connectors detached, the motherboard can be folded over to the left.
  • Take care when moving the motherboard not to allow any of the ribbon cables to be pulled on.
  • The motherboard will still be connected to the body of the phone by the power button's ribbon cable, which is glued in place.
단계 3  ¶
Remove the power button ribbon cable from the body of the phone by using the Plastic Opening Tools.
단계 3  ¶
  • Remove the power button ribbon cable from the body of the phone by using the Plastic Opening Tools.
  • Take care to not damage the button itself or its connecting ribbon cable when detaching the button.
  • The glue which holds the button in place will remain tacky allowing the button to be replaced without the need for additional glue.
단계 4  ¶
With the motherboard removed, the Headset Jack and Ear Speaker are now accessible. Use the Plastic Opening Tools to gently pry up the Headphone Jack to remove it from the body of the phone.
단계 4  ¶
  • With the motherboard removed, the Headset Jack and Ear Speaker are now accessible.
  • Use the Plastic Opening Tools to gently pry up the Headphone Jack to remove it from the body of the phone.
  • The Headphone Jack is held in place with adhesive that will remain tacky after being removed, allowing it to be replace without the need for additional glue.
단계 5  ¶
Disconnect the Ear Speaker from the body of the phone be gently prying up the speaker using the Plastic Opening Tools. The connection holding the Ear Speaker in place is the same kind as the snap on ribbon cables that were disconnected in a previous step.
단계 5  ¶
  • Disconnect the Ear Speaker from the body of the phone be gently prying up the speaker using the Plastic Opening Tools.
  • The connection holding the Ear Speaker in place is the same kind as the snap on ribbon cables that were disconnected in a previous step.
  • With the Headphone Jack and Ear Speaker both disconnected from the body of the phone, they can be removed from the phone and set aside.
