도움말
Wii U GamePad Outer Case Replacement
추천 학생 안내서
추천 학생 안내서
해당 안내서는 저희 멋진 학생들의 노력으로 만들어졌으며 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
Replace the outer case.
  • 작성자: Kim Arre
  • 예상 시간 5 분
  • 난이도: 보통
Use this guide to replace the outer case on your Nintendo Wii U GamePad.
단계 1 Outer Case  ¶
Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers. Lift up the back plate. The back plate is still connected by a cable to the motherboard.
단계 1 Outer Case  ¶
  • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
  • Lift up the back plate.
  • The back plate is still connected by a cable to the motherboard.
단계 2  ¶
Unplug the connector that connects the back plate to the motherboard. Remove the back plate.
단계 2  ¶
  • Unplug the connector that connects the back plate to the motherboard.
  • Remove the back plate.
