도움말
Disassembling Back Cover
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
  • 작성자: Ashley
  • 난이도: 보통
단계 1 Disassembling Back Cover  ¶
Carefully slide battery cover off in a downward direction. Using the plastic opening tool, remove the battery. Light force may be necessary. Using the plastic opening tool, remove the battery. Light force may be necessary.
  • Carefully slide battery cover off in a downward direction.
  • Using the plastic opening tool, remove the battery. Light force may be necessary.
단계 2  ¶
Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
단계 2  ¶
  • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
단계 3  ¶
Using the plastic opening tool, carefully lift the back cover off.
단계 3  ¶
  • Using the plastic opening tool, carefully lift the back cover off.
