메인 콘텐츠로 스킵하기
도움말
OLPC XO-4 Touch Battery Replacement
This guide will walk you through the process of replacing a dead or dying battery in the OLPC XO-4 Touch
  • 작성자: Robby Hubilla
  • 예상 시간 2 분
  • 난이도: 아주 쉬움
Use this guide to replace a broken or dead battery.
단계 1 Battery  ¶
Turn the laptop upside-down, with the handle facing away from you.
단계 1 Battery  ¶
  • Turn the laptop upside-down, with the handle facing away from you.
단계 2  ¶
Pull the lock tabs towards the green outer edges of the laptop. Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
단계 2  ¶
  • Pull the lock tabs towards the green outer edges of the laptop.
  • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
단계 3  ¶
Lift up on the middle of the battery to remove it from the device. Lift up on the middle of the battery to remove it from the device.
단계 3  ¶
  • Lift up on the middle of the battery to remove it from the device.
