메인 콘텐츠로 스킵하기
도움말
Toshiba Satellite M55-S135 Battery Replacement
글머리 기호!
글머리 기호!
더 나은 마크업 및 글머리 기호 색/형식 조정은 해당 안내서를 더욱 깔끔하게 만들것 입니다!
This guide will demonstrate how to replace the battery in your laptop.
  • 작성자: Matthew Trinh
  • 예상 시간 3 분
  • 난이도: 아주 쉬움
This guide will be referred to for other steps because disconnecting the power to your computer is crucial to do before working on it. There are two spring-loaded switches that lock the battery into place.
단계 1 Battery  ¶
Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
단계 1 Battery  ¶
  • Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
  • Slide the unlock switch in the top left-hand corner to the left/unlock position.
단계 2  ¶
Hold the switch in upper right-hand corner to the right.
단계 2  ¶
  • Hold the switch in upper right-hand corner to the right.
  • With the switch held open, pull the battery straight away from the laptop.
