메인 콘텐츠로 스킵하기
도움말
Kindle Paperwhite 1st Generation LED Lights Replacement
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
Use this guide to install new LED lights into your Kindle Paperwhite.
Having trouble reading in the dark? Replace the display's LED lights if the lighting on your Kindle is uneven or absent.
섹션
단계 1 LED Lights  ¶
Use a pair of tweezers to remove the white strip of tape that covers the LED lights. Use a pair of tweezers to remove the white strip of tape that covers the LED lights.
단계 1 LED Lights  ¶
  • Use a pair of tweezers to remove the white strip of tape that covers the LED lights.
단계 2  ¶
Use a spudger to gently remove the plastic screen from the display. The plastic screen is held on by a thick layer of glue. Be patient when lifting the screen to avoid bending or breaking the thin plastic.
단계 2  ¶
  • Use a spudger to gently remove the plastic screen from the display.
  • The plastic screen is held on by a thick layer of glue. Be patient when lifting the screen to avoid bending or breaking the thin plastic.
단계 3  ¶
Once the outer screen is removed from the Kindle, gently use your fingers to pull off the LED lights.
단계 3  ¶
  • Once the outer screen is removed from the Kindle, gently use your fingers to pull off the LED lights.
