도움말
Motorola V551 Circuit Board Replacement
문법 검토
문법 검토
회원님 내면의 영어 교사를 인정하고 해당 안내서의 문법 향상에 도움을 주십시오!
헷갈리는 텍스트
헷갈리는 텍스트
해당 안내서의 어떤 텍스트는 헷갈리며, 중복되었거나 주제에서 벗어났습니다. 편집하여 명확하게 하여 주십시오!
  • 작성자: gregatron
  • 예상 시간 15 분
  • 난이도: 보통
This guide is used for taking apart and/or replacing the computer portion of the phone.
단계 1 Circuit Board  ¶
Remove the rubber screw covers using a plastic spudger. Use a T-6 screw bit to remove the screws. Use a T-6 screw bit to remove the screws.
  • Remove the rubber screw covers using a plastic spudger.
  • Use a T-6 screw bit to remove the screws.
단계 2  ¶
Unscrew the antenna.
단계 2  ¶
  • Unscrew the antenna.
단계 3  ¶
Use a plastic opening tool to undo the latches at the indicated spots. Dental tools may be used in place of a plastic opening tool, as they are difficult to use. Warning: exercise caution as the plastic can break.
단계 3  ¶
  • Use a plastic opening tool to undo the latches at the indicated spots.
  • Dental tools may be used in place of a plastic opening tool, as they are difficult to use.
  • Warning: exercise caution as the plastic can break.
단계 4  ¶
Remove the computer connection (copper flap) by first loosening it with a plastic opening tool. Lift the connection up with your finger.
단계 4  ¶
  • Remove the computer connection (copper flap) by first loosening it with a plastic opening tool.
  • Lift the connection up with your finger.
단계 5  ¶
Use your finger to remove the pressure pad from the buttons on the side of the casing. Remove the plastic flap from around the buttons by lifting it up and pulling it out. Gently lift the logic board up.
단계 5  ¶
  • Use your finger to remove the pressure pad from the buttons on the side of the casing.
  • Remove the plastic flap from around the buttons by lifting it up and pulling it out.
  • Gently lift the logic board up.
