도움말
iBook G3 12" Display Replacement
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
  • 작성자: iRobot
  • 난이도: 어려움
Change out the entire display assembly, including the inverter, Airport antenna, hinges and plastic casing.
섹션
파일
도구
단계 1 Display  ¶
Your laptop should look approximately like this.
단계 1 Display  ¶
  • Your laptop should look approximately like this.
단계 2  ¶
If you have already removed the hard drive in a previous step, your iBook may differ slightly from the picture.
단계 2  ¶
  • If you have already removed the hard drive in a previous step, your iBook may differ slightly from the picture.
  • Disconnect the microphone cable from the front, left corner of the logic board.
  • Peel back the black tape and free the microphone cable from the hard drive.
단계 3  ¶
Use the black plastic handle to disconnect the display data cable from the logic board.
단계 3  ¶
  • Use the black plastic handle to disconnect the display data cable from the logic board.
단계 4  ¶
If you have already removed the modem in a previous step, you can skip this step.
단계 4  ¶
  • If you have already removed the modem in a previous step, you can skip this step.
  • Remove the single Phillips securing the display data cable to the metal framework.
단계 5  ¶
Deroute the display data and microphone cables.
단계 5  ¶
  • Deroute the display data and microphone cables.
단계 6  ¶
Peel back the yellow tape securing the inverter cable to the optical drive.
단계 6  ¶
  • Peel back the yellow tape securing the inverter cable to the optical drive.
단계 7  ¶
Disconnect the inverter cable from the logic board.
단계 7  ¶
  • Disconnect the inverter cable from the logic board.
단계 8  ¶
Carefully deroute the inverter cable from beneath the optical drive.
단계 8  ¶
  • Carefully deroute the inverter cable from beneath the optical drive.
  • Deroute the Airport antenna cable from beneath the optical drive.
단계 9  ¶
Support the display with your free hand while removing the following screws.
단계 9  ¶
  • Support the display with your free hand while removing the following screws.
  • Remove the single Phillips screw on the outer edge of either hinge (two screws total).
  • Tilt the display back to get over two small nubbins, and then slide it directly from the case and away.
