도움말
Toshiba Satellite U405D-S2902 Display Replacement
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
전제 조건 누락
전제 조건 누락
해당 안내서는 작업 시작 방법에 대한 정보가 없습니다. 전제 조건 안내서를 만들어 주십시오!
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
The display on your laptop can be damaged due to drops or other physical trauma as well as internal connection damage. This guide will show you how to safely replace it.
단계 1 Display  ¶
Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
단계 1 Display  ¶
  • Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
단계 2  ¶
Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners. Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
단계 2  ¶
  • Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
단계 3  ¶
Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop. Carefully pull the top away from the back. Carefully pull the top away from the back.
단계 3  ¶
  • Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
  • Carefully pull the top away from the back.
단계 4  ¶
Turn the laptop around. Remove the webcam/microphone data cable. Remove the webcam/microphone data cable.
단계 4  ¶
  • Turn the laptop around.
  • Remove the webcam/microphone data cable.
단계 5  ¶
Remove the lower lighting power supply. Remove the signal light power supply and data cable.
단계 5  ¶
  • Remove the lower lighting power supply.
  • Remove the signal light power supply and data cable.
단계 6  ¶
Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display. After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
단계 6  ¶
  • Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
  • After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
단계 7  ¶
Carefully remove the screen from the side brackets. Remove the LCD ribbon connector from the display.
단계 7  ¶
  • Carefully remove the screen from the side brackets.
  • Remove the LCD ribbon connector from the display.
